Cydia Crashing
Chex
Dec 17, 2008
592
PA
You can't just use cydelete to get rid of it. You need to transfer purchases/backup/restore(preferably as new) then restore from your backup. Then you can rejailbreak. You will need to stay on 4.3.3 or below. So it a bit trickier now that 4.3.4 is out.
Chex
Dec 17, 2008
592
PA
Good luck with that but you can check around, layering a JB is going to lead to instability. It works best on a clean slate, if you can even get JBme to work I'll be surprised. It didn't install for me on an upgrade to 4.3.3, I had to restore as new.
Heck the fact that it's crashing on you already suggests some instability.
Redneck1996
Jan 18, 2011
800
42
23
South East USA
www.prazim.com
I uninstalled it last night and the phone was working fine. So I tried JBme and it didn't work. I've decided to stick to Icy for now.
Then I wake up this morning and it's in infinite boot loop. So I used TU to kick it in and out of recovery a couple times and it's been working ever since.
Sent from my iPhone
avin7000
Jun 7, 2011
170
okay n00b question here, after un-installing cydia can't we just install it by .deb downloaded from safari ? If not, den why ?
computerfox
Oct 2, 2009
3,550
New Jersey
www.abelgancsos.com
the only way i see that possible is by running a few terminal commands, but then again, i believe that the .deb has to be installed via iPhone. my suggestion is as chex said, you want to re-jailbreak it. i had this problem a few times in the past and that's really the only way to have a stable jailbreak after something like this. also, why jbme? i used that site a couple of times when first upgrading to IOS4, but since there are a few programs out there that give you a stable jailbreak, why not?
computerfox
Oct 2, 2009
3,550
New Jersey
www.abelgancsos.com
You mean to say jbme won't give stable jailbreak ?
i don't want to assume, but it would depend on how he upgraded. if he upgraded straight from Apple, it could be the jailbreak, meaning it could be that Apple implemented some crash protocol on the jailbreak or the jailbreak itself went bad.
if he got the build from somewhere else, it could be a bad build. it has happened to me a few times.
besides, don't you need a sim to get to jbme anyway? unless, in this case it was an upgrade and/or there might be an AT&T sim. jbme is fine if there's nothing else or one just prefers using the web-based jailbreak.
avin7000
Jun 7, 2011
170
but jbme is ********* easy.
and I didn't knew RedSn0w require sim where jbme doesn't. Thank you :)
[Post edited]
Chex
Dec 17, 2008
592
PA
I think the op had stuff going on with their phone that can't be discussed here... I'm just reading between the lines(shrugs). Thats usually the reason to avoid a restore when your having those problems. Not an issue for the rest of us.
Sent from my iPhone 5 using iCafe app
