Cydia Crashing?
nobopyon
Jul 11, 2008
393
Dallas, TX
I have recently JB my iPhone 4 (iOS 5.01) with redsnow_mac_0.9.10b3.
I have issue with cydia keep crashing whenever I need to type in something, for example, when I want to search something, the moment I touch the text box space, cydia just crashes.
Even when I went to some app, and it requires for me to type in facebook/google login for authorization, cydia crashes the moment I touch the text input box.
I have tried 3 re-JB (restore it to default, then JB).
I even tried iExplore to delete everything inside of private\var\lib\lists except "partial" to see if it will fix the crashing... but still no luck.
I just want to purchase "Tetherme" app, but it require me to type in something....
what is wrong? any way to fix?
Thank you,
fijiman
Feb 13, 2011
832
64
UK
Have you tried a simple hard reboot?..... Hold power and home button until you see the Apple logo
Try this (if you can install SSH without it crashing):
To start with, launch Terminal and type in su root. Press enter after typing.
Type alpine and hit enter again.
When you're done typing alpine, put in apt-get remove Cydia and press enter. You'll see a warning pop up, which you'd have to press enter for. Then again, type apt-get install Cydia. Your Cydia should open now without troubling you anymore.
