Cydia Icon Dissappeared after deleting a tweak i never heard of :GNU Privacy Guard
S
Sabis
Guest
How to get back the Cydia without restore and losing all my files?
Dec 15, 2008
5,386
340
Pensacola, FL
I see the GNU Privacy Guard now when I go into Expert mode. This is needed with Lydia. It came with Cydia when you jailbroke.
Search for only GNU and you'll see it. Don't include the : .
EDIT: I'm silly. You said you don't have Cydia anymore. Try searching for it with spotlight perhaps. If not, you'll have to re jailbreak and all.
5,578
Try a hard reset. If that works, reinstall the package. It has a significant purpose. It verifies all signatures in package downloads.
S
Sabis
Guest
Did a Hard Reset...but the problem is Cydia is not there anymore....
No resulats after Hard Reset :(
5,578
Can you access it through Spotlight? If not, I think you'll have to restore.
S
Sabis
Guest
What is Spotlight?
S
Sabis
Guest
oh i got it.....nope its not there,....
S
Sabis
Guest
Ive Restored and its done......
I want to ask another thing umm...im using ios 7.1.2 and ive used latest version of pangu.......do I need to download complete PPSync remover?
S
Sabis
Guest
And another thing I had an update of this GUI-GPG-SEC from cydia...after I updated it says files installed to Cydia.app
same thing with another tweak it says files stored to ds store....what do I about it?
