Cydia info requet
ajh051453
Dec 8, 2008
14
After jailbreaking my iPhone I opened Cydia and received the "Who are you" option. Being totally new to iPhone & Jbreaking, I could use some help. I am not sure at this point if the command line will eventually be needed. Which prompt should be selected and why. the User or Hacker (+command line). I am sure I don't need to select developer. Lots of info available on this forum but not to the specific question. Thanks to all that respond.
Nov 2, 2008
19
it doesn't matter you can select user to start off with and later if you find the need for the hacker option you can always change it in the settings on cydia
ajh051453
Dec 8, 2008
14
As I stated. This is all new to me. Thank you for your response.
