Cydia Not Refreshing
Dec 15, 2008
5,386
340
Pensacola, FL
Hello Jailbreak Family! My Cydia app on my iPhone 5, iOS 6.1.2 has not been refreshing at all for the past 5 hours. It refreshed just fine earlier and showed new tweaks/apps. Now it is saying "Error: POXIX: Connection refused."
Dec 15, 2008
5,386
340
Pensacola, FL
Is one of your sources down?
Winterboarder has always given me an error after Cydia fully refreshes. But today has been strange. Cydia would fully refresh and show me 7 or 8 errors. It was fine at around 5 P.M. Now Cydia is not refreshing fully at all.
Sent using iCafe app
Jun 19, 2007
33,483
4,545
Upper Marlboro, MD
I was referring to a source, not a program. A source (or repo) is the group that hosts the program, such as BigBoss or ModMyi. You can find them in Cydia under Manage>Sources.
Dec 15, 2008
5,386
340
Pensacola, FL
The cydia.winterboarder.com has always been under sources but has been empty. My other sources, the ones you mentioned and others are just fine. I haven't added any sources at all besides one a while back that came with it when I installed All Sources.
iphonewarrior
13,847
702
Remove the Source from your device, then refresh it should stop throwing errors at you. Another useful app for any jailbroken iPhone is iCleaner (I may even do an in depth post about how to use it). You can run iCleaner to get rid of those pesky errors within Cydia.
Dec 15, 2008
5,386
340
Pensacola, FL
Thank you. I removed winterboarder which removed all sources which is fine. I have no more errors. I also used iCleaner.
AdamDaieh
Jan 17, 2013
141
California
I also use iCleaner to get rid of all errors. A must have in all iDevices.
