Cydia on beta 3.0
Jack06
Jan 6, 2009
122
Hi guys
I'm thinking of upgrading to 3.0 and wanted to check if cydia is available on the beta version.
Also what main things will I miss out from 2.2.1 if I upgrade?
iNinja
Aug 8, 2008
3,985
20
UK
Everything stock from 2.2.1 is (should be) available on beta 2. You may find some apps don't perform how they should as 3.0 is still a beta. Jailbreaking is still an option but honestly, what is the point? You have a lot of features with stock 3.0 and as its a beta you will have to re-jailbreak (if possible) when a new beta is released, every couple of weeks or so!?
Jack06
Jan 6, 2009
122
Hi Croucher
thanks for the reply, and the beta version is available through torrent websites would that be right?
Jack
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Its available that way, but you need to make sure you are registered as a developer. And I definitely wouldn't recommend jailbreaking it, nothing works, and like Croucher said, 3.0 covers most of the better points of jailbreaking anyhow
iNinja
Aug 8, 2008
3,985
20
UK
I agree with Adam - DO NOT UPDATE TO 3.0 WITHOUT REGISTERING WITH A DEVELOPER!
