Cydia section for iPad
verbalj
Jan 12, 2010
390
NYC
Is there a section in Cydia (that I'm totally missing) that lists all available iPad tweaks/apps?
Furthermore, if there isn't such a section, other than the developer writing in the description that it's iPad compatible, is there any other way to know if it is?
Lastly, if the dev doesn't write in the description that the app is/isn't compatible with the iPad, is there a general rule of thumb for iPad compatibility? For example, just for the sake of argument, any iPhone multitask bar jailbreak tweak won't play nice with the iPad so on the iPad we should just avoid them all together.
I just received the iPad 2 yesterday, so I'm new to all the jailbreak stuff for it.
iphonewarrior
13,847
699
If you launch Cydia and tap Sections, you can then tap Edit in the top right corner. This allows you to toggle On/Off sections in Cydia. This may help you find things in Cydia easier...
