Cydia Substrate Updated for iOS 7 (32 and 64-bit)
iphonewarrior
13,847
701
Guys, it's finally been updated!
Cydia Substrate is now live on Cydia.
PreferenceLoader has also been updated. :p
Please Note: From what I've read it's imperative that you uninstall the, Mobile Substrate Fix first before installing Cydia Substrate.
iphonewarrior
13,847
701
I suspected there may be issues with the non-Saurik fix which is why I didn't install it, even though he implied it was fairly safe to do so..
I un-installed it without reading any of the warnings, just in case it did break anything. The temp fix worked great for me, Barrel worked even without an iOS 7 update. I'm excited to see what great tweaks we're going to see over the coming weeks/months.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I just caved and bought Barrel. Yeah, you all might think I have been crazy not to buy it in the past, but hey I don't know. Now I was looking at awesome tweak videos for iOS 7 and it continued to mention Barrel, so I bought it. It is awesome, but one thing I did find out is when you choose to hide icon / show icon, it does just that but it also sends your iPhone to safe mode.
28,365
5,506
I did that several times and it never put my phone in safe mode. I ran it for several days and didn't experience a single problem, but then got bored with it and uninstalled it. It's probably incompatible with one of your other apps if it's causing safe mode crashes.
Dec 15, 2008
5,386
340
27
Pensacola, FL
This is the first time I've used Barrel. It works, but it sends iPhone to safe mode when I choose to hide icon or show icon. No big deal at all, but I have decided to show icon just in case I want to change the setting quicker.
28,365
5,506
I understood your post the first time. What I've been trying to say for a while now is that running as many apps as you run is going to cause problems of this sort.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Actually, I went through and removed what's not compatible and made sure none were repeats. I don't have many tweaks now. Only a few apps.
28,365
5,506
I didn't mean incompatible with iOS 7; I meant incompatible with each other. It's very tricky when you have 40+ Cydia apps/tweaks. I was just trying to help you avoid safe mode crashes etc. when I brought it up a week or two ago.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Yes, and I removed stuff. Unfortunately, I don't know what's incompatible with each other. But right now I have no issues which is great. I'm assuming the safe mode when I choose for Barrel icon to not show or to show is an issue with Barrel. Can you try?
28,365
5,506
I tried it numerous times last week when I had Barrel and I didn't have a single safe mode crash. The icon wouldn't hide, but trying to get it to do so didn't cause a safe mode crash.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I tried it numerous times last week when I had Barrel and I didn't have a single safe mode crash. The wouldn't hide, but trying to get it to hide didn't make it crash.
You chose in the app icon to not show the icon and it didn't crash to safe mode? Alright. Well I'm not sure what could be causing it. No big deal. I don't want to continue this here lol. :)
iphonewarrior
13,847
701
@MoneyMaker79 Late to come in here (mad crazy week). What's Crash Reporter saying after the Safe Mode crash? I know you may not think it's relevant, but sometimes it can give you a good indication on what may be causing the issue. Do you have any Activator actions controlled by gestures on the Springboard? Do you have any folder tweaks etc? I know you said in a previous post that you don't have many - which ones are they?
Dec 15, 2008
5,386
340
27
Pensacola, FL
The only activator action I have is to start "recordmyscreen." I don't have any folder or folder tweaks or icon tweaks besides five icon dock. Crash Reporter usually gives an instant report of what is causing a safe mode crash, but it does not.
iphonewarrior
13,847
701
How do you invoke recordmyscreen?
Dec 15, 2008
5,386
340
27
Pensacola, FL
That shouldn't really affect Barrel. What other Springboard apps do you have which could possibly influence Barrel?
The only thing that causes Barrel to go to safe mode is when I choose for the icon to show or not to show. It's no big deal.
This is my Cydia Springboard page if that's what you mean. I just removed YouMP3 as it doesn't work anymore.
