Daisy Disk - Hard Drive Scanner
iphonewarrior
13,847
699
I recently realised that I had a large portion of my MBP's hard drive, I couldn't work out where all the space was being used up. After scanning my Mac with various free tools from the Mac App Store they didn't really do the job I wanted them to do i.e show me what was taking up all the space?!
I stumbled across Daisy Disk and thought I'd give it a go. This app is awesome and it should really have an equivalent Mac OS X native app, built into Disk Utility. What Daisy Disk does is visually map your computers HD and/or attached HD's including Dropbox folders externel USB drives etc.
Here is an overview once you've scanned a particular drive.
When you hover over the segments you get an overview of what that folder is and it's contents, obviously the bigger the segment the larger the file/folder. Really handy when trying to determine where large files or folders are quickly.
When you've selected a segment this is what you'll see (not my favourite choice of music...) this.
After spending roughly 50 minutes scanning and determining what I do and don't need I managed to clear over 100gb of unused crap.
The app is currently on sale and totally worth the price.
Link: http://itunes.apple.com/gb/app/daisydisk/id411643860?mt=12
*I am in no way affiliated to this app or the developers.
fury
Oct 23, 2007
2,274
236
34
Louisville, KY
This looks really, really nice. I've been using WinDirStat on PCs, and Disk Inventory X on Macs, they both look and function about the same as each other, which is to say...not particularly nice-looking, but functional.
If I had to do disk usage analysis more often than once every few months or so, I'd probably want to do it in style with this one. Nice find
iphonewarrior
13,847
699
It"s a great little app, really can't recommend it enough. It just makes life easier.
