data recovery on ipad storage device?
marina
Jul 4, 2016
los angeles, ca
I have an ipad 2 which is dead (bought an ipad 3 as replacement). Is there a way to recover the data from it?Yes, I know that the icloud backup contains some of this - but I hadn't backed up my game data in a while so I know that the last backup is not current. And yes, there are some games that even if you DO have connected to the game center won't recover your progress upon a restore unless you specifically backed up your game data. I know the hard drive is really a flash memory device on the logic board, does anything exist allowing to connect that to my desktop and pulling the data from it? Or does something else work? Or am I completely SOL? Thanks.
Andyacb
Aug 12, 2017
Another way to recover data from the dead iPad is, connect your iPad to PC and see if it can be detected inside your PC.Then try to extract all the data from the hard disk directly. It is hard to say whether the dead iPad can be identified. Hope you would be the lucky one.
RoofMonkey
Jun 21, 2010
8,913
1,979
Original,post is over 1 year old and.... 'extract all the data from the hard disk' ???? An iPad has a hard disk drive? LOL
