Dead Pixel - 3GS
Andrios
Jun 27, 2009
22
Damn I just got a 32g white 3gs and now there is a green pixel showing in the middle of the screen :(.
I got it at Best Buy on the 26th, should I just go back and get a new one?
john_T
Dec 29, 2007
688
NYC
Definitely. I had the same problem and I got a new one with no problem. You paid for it and it should be PERFECT.
Andrios
Jun 27, 2009
22
Sucks though cause the best buy I got it from had limited stock, so they probably all gone now lol.
Get_Zwole
Jun 20, 2009
318
Oklahoma City
I bet if you have an Apple store near you and you take it in they will just give you a new one. Definitely take it somewhere you will get a new one either way.
Andrios
Jun 27, 2009
22
I will, thanks guys!
Andrios
Jun 27, 2009
22
ok...woke up this morning and now the green pixel is gone. You think it will come back or did i just get lucky it went away?
Phxblue
Apr 13, 2008
467
The Valley, AZ
Sounds like you are good to go. If it does come back then exchange it because that tells you it will most likely be a common problem that will continue to come and go.
john_T
Dec 29, 2007
688
NYC
It was a stuck pixel then. they tend to come and go. Watch out for it.
