Decrypter, please help..
HUNTER1
May 28, 2009
404
I installed a dvd43 decrypter and while it was decrypting I cancel the process. Now, it's giving me an error that it was not properly installed. I tried to remove it from control panel and it won't allow me and it's saying to close all instances. I tried to reinstall it and it's giving the same message and also saying that my driver is not active because of that. So now I can't even use the driver. What can I do to fix or uninstall this? thanks
HUNTER1
May 28, 2009
404
Anyone has any idea on how to fix this?
styfle
Mar 31, 2008
3,381
Kill the process if its still running.
5,578
I assume you already rebooted the computer and the problem persists. Put the computer in safe mode and uninstall it.
HUNTER1
May 28, 2009
404
Thanks guys, I will do as suggested.
Got it done, thanks again
