Delete "loading applications"
President
Sep 1, 2011
Hi all
I downloaded about two yoga applications on my iPad2, but both were over 20MB so now they are stuck on "loading" and cannot be deleted. Anyone know how to delete the apps? Thanks
5,580
Try rebooting the phone.
iphonewarrior
13,847
702
I second Europa. If the download stalls, simply reboot the phone. If that doesn't clear the problem you will need to connect the device to iTunes and click the check for available downloads tab. Doing this will download all outstanding applications and sync the device.
termleech
Sep 7, 2007
1,154
McPherson, KS
You can also switch the device to airplane mode which I believe will time out the download. This should give you an error and delete the pending app.
Tapped via my Alien Droid.
