Deleting a plist...bad news?
fearofnormalcy
Jul 8, 2010
1,742
118
New Port Richey, FL
www.facebook.com
In pointing out biteSMS's "Hide Contact" feature to another forum member, I realized that I had forgotten my own password. After checking around online, I found a possible solution: delete the biteSMS plist in /var/mobile/Library/preferences.
Is this a bad suggestion, or will it work? I've edited plists before, but never deleted one completely. Just wanted to check to see if all will be well.
Also: If it's kosher, should I respring or reboot afterwards?
iphonewarrior
13,847
702
A reboot will probably be required. Why are you deleting it? Because you lost your password?
5,580
Reboot after deleting it. If that's where it's stored, it should fix it by recreating the file on reboot. Can't hurt to try. Just back it up first.
fearofnormalcy
Jul 8, 2010
1,742
118
New Port Richey, FL
www.facebook.com
E
Yup. Not that it's a big deal, but it annoys me that I've forgotten my own password. Tried all my usual ones, and still can't get in.
I think I set it back when I was inebriated....
fijiman
Feb 13, 2011
832
64
UK
Go for it...In the early days of "FullDrop"(in Cydia) I had a problem with my password...I was advised by the author of FullDrop to delete a .plist file then reboot.... fixed the my problem....funny thing, when I rechecked the folder the .plist file was back minus the password problems..:)
5,580
Yeah, the missing file is recreated during the reboot.
