deleting apps
Oct 2, 2007
I have a couple of apps showing on my iPhone and I'm not to sure how to remove them. I checked through the installer app and couldn't find them so I can't figure out how to remove them. Pls help! The apps I'm trying to remove are iSaber, Terminal and VRecord. Thanks
akophone
Aug 1, 2007
300
Just tapp on Installer. Select the Uninstall pane and select the apps!
Oct 2, 2007
I tapped on installer and went into unistall but they are not listed/showed in the pane, that's why I'm confused.
akophone
Aug 1, 2007
300
Hmmm. Strange. Well, you can always perform SSH. But since you already have the Installer, why not install rSBT? That way, you can hide the apps...
