deleting contact groups
bangex
Aug 15, 2012
hi. badly need help. i accidentally synced my iPhone with my yahoo address book and now there's a from my pc contact group in my iPhone. how do i delete the group?
Girdler
Aug 1, 2012
283
44
30
The only way that you will be able to remove the contacts group from your phone is by syncing again. This time, however, you will un-check the syncing for contacts within iTunes.
bangex
Aug 15, 2012
i tried it already but it didn't seem to work. i'll try it again, thank u!
Girdler
Aug 1, 2012
283
44
30
If un-checking the sync does not work through iTunes to remove the group, the only other ways to remove that group would be to either sync with another source for contacts, or to restore the device as new.
