deleting individual calls
hummrock
Nov 14, 2007
does anyone know how to delete individual calls out of your recent calls without deleting all calls?
enigmanic
Jun 27, 2007
513
Unfortunately, as petalmom states, it's not possible on a stock iPhone. It can be done via third party apps (the app is called CallID), but that involves jailbreaking your phone.
CallID does delete the calls, but it's a separate app, not a plugin, as I would like it be.
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Yeah other than the apps this has yet to be fixed by Apple. Oh the joys of awaiting updates.
scandalex
Sep 16, 2007
771
I've used it and it works very well.
I just wished it showed names or names with the numbers. The fact that it displays the phone number only sometimes has me worried that I'll delete the wrong number.
I don't know anyone with a cell phone that actually remembers a phone number these days. :p
Hondamaker
May 14, 2007
9,946
671
57
Fairborn, Ohio
I know what you mean. I've had to go back to Recents to find out what the number is, then go back to CallD and the delete the call.
Miller
Dec 27, 2007
what are a "third party app" and "jailbreaking"?
faramir
Nov 4, 2008
hiya,
Im having trouble loading software that will allow me to delete individual calls on my iPhone 3g. I downloaded isms but i can't get it onto the phone? I've never actually loaded any software onto the phone before so I'm not even sure I'm doing it right? I'm opening the applications on iTunes and trying to drag it into the box without sucess? am i doing this right or can anyone suggest an alternative software or other way of going about this...?
Thanks to anyone who can help...
F
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Welcome to EIC!
If you are jailbroken there are several options for you available on Cydia. I'm not sure what they're called but I bet with a few searches you could find them. Good luck.
cu0ngsayz
Mar 10, 2008
53
I jailbroke mine but when I opened the callid it would open then just close is anyone having this problem?
Zameus
Sep 23, 2008
That's why I went with an Android. Apple just misses all the logics of it all.
