Deleting programs
ur4me
May 5, 2009
Hi All
After utilizing my 3giPhone fpr over two months now i have noticed that most of the software applications which came with it have ceased functioning.
Is there a way to get them work or i have to purchase them?
How could i possibly delete some of the programs which i don't need.
regards
5,578
You can't delete the stock programs, just the ones you download through the apps store. If you want to delete them, touch and hold the app icon for a couple seconds until the icon starts shaking, and then press the "x" on the icon to delete it. If your apps have stopped working, you may need to update the firmware (FW) in iTunes. If you already have 2.2.1, you may need to restore the phone in iTunes.
ur4me
May 5, 2009
Thanks m8 .
regards
