dial pad
Dec 13, 2007
25
utah
can some one post the path to change the dial pad picture?
thanks
Dalton
Dec 13, 2007
25
utah
thanks
Dalton
ok I found part of what I was looking for, but my question is, some how I got some christmas/ holiday bells for my dialer background. and I can t seem to fix it. I have changed a couple different files. so if any one can help I would appreciate it.
thanks
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
You replaced the MobilePhonePackedImages.artwork file in your /Applications/MobilePhone.app directory. To fix it you will need to get hold of an original copy of that file to replace it. There may be aftermarket software that can change the images for you but I don't know what they may be.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Here is the original file:
You need to SSH this into the correct directory and then reboot your phone for it to apply. Once done your dialer will be back to the stock one.
Dec 13, 2007
25
utah
thanks griffanz, worked perfectly
