dialer help.
H
Hayesimus
Guest
k. i downloaded this nifty payphone keypad file. but i loaded it and it showed for a split second and then the buttons reverted to the standard dark blue squares. so what am i doing wrong? i need a little help! :S
akophone
Aug 1, 2007
300
Have this dialer right now. Never had a problem. I performed SSH (sftp), replacing the files provided by the Old School Dialer in MobilePhone.app folder and have had success, even with the version 2 that just came out. Some have been having some issues with Customizer installed but so far so good for me.
ChemicalWeather
Sep 9, 2007
64
this was happening to me, to fix all i did was delete whatever file(s) you added, restart iPhone, put on files, restart iPhone then it worked for me
