Difference between iPhone 6 and iPhone 6 plus
rugved1118
Sep 27, 2013
644
Hello,
Can anyone tell me the difference between iphone 6 and iphone 6 plus ?
Sent from my iPhone using iCafe Forums
-- iphone5, iphone4 and ipad2-wifi+3G
Aug 1, 2007
1,232
44
Bigger screen, higher resolution. Better battery, and has optical image stabilization (much better than the 6). that's about it.
dallasjetfan
Oct 15, 2011
308
45
Much better specs but screen size will be problem for many. I know that was my deciding factor of getting the 6 over the Plus.
Rafagon
Dec 7, 2011
7,566
1,254
45
Miami, Florida
Oddly, the display of the iPhone 6 has better contrast ratio than that of the the iPhone 6 Plus: 1400:1 on the 6 versus 1300:1 on the 6 Plus.
However, the difference should be unnnoticeable to most normal human beings. Additionally, both are significantly better than the contrast ratio of the iPhone 5s, which is 800:1.
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
The only thing keeping me from my final decision is if I want the upgrade for OIS. I'm not quite sure its worth the wait or the extra cash.
In all likelihood if they have a 128GB i6 in stock in my podunk AT&T store, I'm going to get it and not get the i6+.
Jim
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
There's a lengthy write-up on the iPhone 6 vs iPhone 6 Plus. The biggest differences are the size of the display, optical image stabilization on Plus and support for iPad-like software experiences on the bigger model.
thevlad
Oct 12, 2011
57
one Plus is the difference.
