difference between WinSCP and iPhoneBrowser?
callisto9
Feb 12, 2008
403
IOWA
from a basic standpoint, what's the difference between these two programs? from what i can tell, iPhoneBrowser is easier to use, so what do people use WinSCP for?
thanks in advance.
eTEK
Oct 7, 2007
45
WinSCP you don't need to have your iPhone connected to your computer via usb.
As long as your phone is on a wireless connection you can sync wirelessly.
iPhonebrowser needs to be connected
callisto9
Feb 12, 2008
403
IOWA
thank you. that helps!
what are people syncing over WinSCP?
eTEK
Oct 7, 2007
45
yeah like if you decide you would wnat to jailbreak your iPhone and you want to install a gameboy advanced emulator on your phone you would use winscp to add games on your phone.
callisto9
Feb 12, 2008
403
IOWA
you couldn't do it on iPhoneBrowser?
i'm looking to do a NES or SNES emulator next.
callisto9
Feb 12, 2008
403
IOWA
i can rarely get WinSCP to work. any ideas why? i have SSH on, but i always get the error message: Network error: Connection refused.
i have all the settings correct, i've been in before. what gives?
enigmanic
Jun 27, 2007
513
I started having this problem after doing the new ZiPhone jailbreak too. It would work initially, but after turning off SSH and then trying SSH again later, I'd get a network error. I'd have to restart my phone in order for the connection to work again. I think I figured out the problem though: I was using Services to toggle my SSH on/off. After installing and using BossPrefs instead, I haven't had a problem since.
P.S. Another advantage of using WinSCP over iBrick or iPhonebrowser is that you can easily set file permissions and run command lines. This is particularly useful if you need to install apps manually.
callisto9
Feb 12, 2008
403
IOWA
yeah, i've turned off/on SSH via Services.
i'll try the BossPrefs thing. thank you.
Tinman
4,334
183
Aridzona
thanks in advance.
I use both. But I mainly use iPhoneBrowser/iBrickr when SSH is off for some reason and I need to get into my iPhone (used to get a lot of lockups under 1.1.2, when installing apps, that could only be corrected by going in via SSH/iBrickr).
WinSCP/PuTTY allow anything to be done on the iPhone, whereas iPhoneBrowser is much more limited: can't set permissions, can't execute apps, can't use a command line, can't edit plists in-place, etc. As an example I use SSH to take screenshots on my iPhone (snap, snap2camera, etc).
Mike
callisto9
Feb 12, 2008
403
IOWA
ah, i gotcha. thanks again for all your help.
i'm kinda scared to jailbreak again. :mad: right now i'm back on 1.1.3 stock.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
I also use both. The main difference between the two for me is where I am at the time I need to work on the phone.
If I am at home and connected by WiFi then I use WinSCP because it is more powerful of the two. In that program you can rename folders, bring up command prompts and type commands, etc...
If I am at work where I do not have access to WiFi I use iPhoneBrowser. I like the simple interface and ability to quickly look at the directory structure or copy files to and from the phone. If there are permissions settings and such that need to be done I just use the term-vt100 program on the phone.
So, in my opinion they both have the same basic functions but iPhoneBrowser is more of a simple task program where WinSCP is much more powerful.
callisto9
Feb 12, 2008
403
IOWA
thanks for the additional input griffinaz. i'm still kind-of a basic user, but this helps me out!
jailbroke again for the 3rd time now! woo!
6,682
49
I am having the worst time trying to connect with the phone through either Term, winscp, or PuTTY. Connection is always refused.
Anyone have any ideas?
enigmanic
Jun 27, 2007
513
Hawk,
Are you jailbroken on 1.1.3? If so, Services and NetServices are buggy with SSH -- even though it appears to turn on/off SSH, it does not. Use BossPrefs instead to toggle on/off SSH.
6,682
49
Hawk,
Yes, jailbroken 1.1.3 from ZiPhone 2.1. I have BossPref's installed, but I cannot connect. Term vt said invalid login (used root@iPhone IP with password "alpine")
Winscp says "Connection Refused".
OMG I am such a DUMBASS. I got it. Out of embarrassment, I keep what I was doing wrong to myself.
brzman1
Aug 14, 2007
73
Miami, Fl
Question. What are file permissions for? How do i access them? Also, in order to connect to WinScp, you have to shut off the SSH? Do you even need to install SSH? Sorry for the questions; still learning
callisto9
Feb 12, 2008
403
IOWA
in order to access the iPhone via WinSCP, SSH needs to be ON.
as for file permissions, i have no idea. sorry. i'm learning, too. :laugh2:
