Different Apple ID
shugo
Sep 3, 2011
84
The Apple ID that I am using is different from the one that pops up. Instead of "@gmail.com" it's showing "@gmial.com" I have apps that won't update because "I have not verified this Apple ID", and it's getting rather annoying. Is there a way to fix this issue?
Sent from my iPhone 4S using iCafe app
shugo
Sep 3, 2011
84
Tried that, still pops up with the need to verify message.
ed2438
Apr 9, 2010
365
24
El Paso, TX
Go to setting, store. Press the account name and Sign out there.
Sent from my White iPhone 4S using iCafe app
shugo
Sep 3, 2011
84
I've used that Apple ID to purchase apps, and since @gmial is not a valid email extension, I can't verify it on this iPhone.
15,385
1,023
open iTunes, sign into the original AppleID, and click on "iTunes Store" in the left column.
at the top right of the iTunes store, you'll see your AppleID. click on it and sign in with your password.
at the top of that screen you will see the "Apple ID" field with "Edit >" to the right. Click on edit.
On that screen you can change the email address to the new valid one.
shugo
Sep 3, 2011
84
It won't let me get past the log in. As soon as I tried, the verify pop up appears.
ed2438
Apr 9, 2010
365
24
El Paso, TX
How about de-authorizing the computer. Then signing in with different id?
shugo
Sep 3, 2011
84
That's just it, I can't log in to de-authorize the computer, and since I've tried to reset things, I can't even log in to it anymore...
