Dims slightly, randomly
Cloverfield
Jan 16, 2008
715
30
UK, Kent
www.CloverfieldMovieForum.com
So I've been using my 5s for about 15 hours now and I've noticed every so often the screen will dim slightly by itself. If I go to the brightness setting if it is around 70% up the bar no matter how much further to 100% I go it remains the same brightness unless of course I go below 70% and then the screen gets darker. There is no way to make it brighter. After about 5 minutes maybe more the screen goes back to the brightness it was on. Very strange, anyone else had this yet?
Dec 15, 2008
5,386
340
29
Pensacola, FL
I am unsure about the 5s, but the 5 will change brightness depending on the lighting you're in.
Sent using iCafe app
Dec 15, 2008
5,386
340
29
Pensacola, FL
No, automatic brightness is off.
I see. I just researched online and found that people are having this same issue, but with an iPhone 5 on iOS 6 and 7. I haven't found any questions regarding it on the iPhone 5s. From what I found though, it sounds like it is an issue on the operating software itself.
