Disable all data connections besides WiFi
Jul 13, 2008
hey,
Well, I think the subject is quite self-explanatory... I want to be able to turn on and off data connections on iPhone 3g, more precisely, celular based data connections... I need to be sure the iPhone won't go connecting to the internet every time I want to read an already downloaded email...
Is this possible?
regards.
rf
stevetim
Jul 20, 2007
606
airplane mode. Only negative is no phone calls.
Jul 13, 2008
yeah... that wasn't really the solution i was hopping for... on the original iPhone you could just change the EDGE configurations and it wouldn't be able to connect, but on the iPhone 3g you can't do that... at least I can't find it....
rf
equlizer
Jul 13, 2008
you can shut off "3g" if you want under options. This wont stop it 100% but its a start.
Jul 13, 2008
im sure there has to be a way, call Apple or att
i'm not from the states and i bet my own celular network won't give me a better solution than airplane mode... i'll try Apple...
thks anyway. anybody has got any more ideas?
