disable edge?
tankster
Nov 6, 2007
9
Hello all!Is there a way to disable edge? I have downloaded the "services" program and i turn off edge from the program but when i go back into the program it says it is on.Is there a for sure way to disable edge? I do not have a data plan and i am on a computer all day and i don't need the convenience of edge when i have wifi everywhere i go. And i don't want to get hit with a heavy bill on my next statement.Thank you in advance :)
420greg
Jun 26, 2007
845
Orlando, Florida
Is the little E on the status bar reappearing? Or is it just 'services' that is saying it is on?
tankster
Nov 6, 2007
9
i went in to services > turned off edge and it says it is off but the "E" is still present at the top :(
tankster
Nov 6, 2007
9
also, if i restart the phone, "services" says edge is turned back on. So it seems eveytime i restart it goes back on and i have to go in and turn it off manually but the "E" is still present even when i turn it off :(
420greg
Jun 26, 2007
845
Orlando, Florida
Do you have email set up to check every few minutes? It may be activating edge to check for email.
tankster
Nov 6, 2007
9
ok i found out what is going on. It acutally is turned off even though the "E" is still present! Weird huh? I tried accessing safari or any other thing that involves internet access and it says "cannot connect to server" . Currently there is no wifi where im at so i think im good. But when i restart the phone it turns it back on so its not too big of a deal, i just hope i remember to turn it off everytime i restart the phone! thanks for your help!
