Disable need to lift iPhone to turn off alarm
AppleMicrosoft
Nov 21, 2010
54
When an alarm goes off, no amount of hitting the Stop button in various ways seems to turn it off unless I lift the phone. Is there any way to disable the requirement to lift the phone?
AppleMicrosoft
Nov 21, 2010
54
Clarification: Lifting the phone by itself doesn't stop the alarm, and neither does pressing Stop alone. I have to life the phone *and* press Stop.
I am using iOS 11.2.6 on the iPhone SE.
RoofMonkey
Jun 21, 2010
8,912
1,979
I’m using 11.2.5 on a 7plus. Just set an alarm to go off a minute ago. Phone was laying down, screen off.
Alarm went off and all I did was tap the stop button (did not lift the phone up at all) & the alarm silenced as normal.
Have you tried a reboot of the phone itself? When strange things happen, that’s the first thing I do and it seems to fix 99% of the problems.
I’ll update to 11.2.6 soon and see if it changes the stop feature.
EDIT: just updated to 11.2.6 and can still shut off an alarm by only pressing stop on the screen.
AppleMicrosoft
Nov 21, 2010
54
Yes, I reboot daily. Next step is Reset, and failing that, reset to factor default. I haven't yet decided to go ahead with those.
