display temporarily larger than screen
jfleming01
Apr 29, 2009
150
weird issue last night. Damp night, but phone did not get wet, was in my pocket. Turned it on when I got home to check battery level and it wasn't showing at the top. Realized slide bar at the bottom was partially obscured, if I moved my finger over screen the image shifted, even kind of pulsated. Turned it off and back on, everything is normal. Dampness? Halloween? normal? Thanks
Not normal. Not halloween. Possibly moisture.
You hadn't said Beetlejuice three times have you?
Sounds like it could be a temporary display of bad behaviour based on the dampness.
Willsrx
Jun 26, 2010
51
It could be that you have the zoom setting on in the accessibility menu, it will magnify the entire screen including the lock-screen with a three finger double tap.
