Distorted audio
Rickster
Aug 28, 2011
20
Afternoon all. Experiencing a strange problem with my iPad mini. Occasionally following switching on (from cold) all audio comes out distorted.This includes all system sounds as well as music tracks and video sound as well. Anyone else had this and if so how did you cure it.
I usually do a hard reset which sorts it out although a soft restart has also worked. Seems completely random just shows up when iPad is booted from completely off.
Rick
Rickster
Aug 28, 2011
20
It usually happens when starting up from fully off and then not every time.
Not sure how you could run any further checks on the speakers.
Ledsteplin
Oct 29, 2013
4,824
987
65
Florence, AL
Close out all background apps.
Do a hard reset
Reset all settings Settings>General>Reset>Reset All Settings
Rickster
Aug 28, 2011
20
Thanks will give that a try later tonight.
