DND moon greyed out during use, but not in the lock screen
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
I just noticed that my DND moon icon is greyed out on the home screen (and seemingly everywhere else), but it is displayed at full brightness on the lock screen. Does this mean anything?
image.jpg Greyed out
image.jpg Not greyed out
RoofMonkey
Jun 21, 2010
8,867
2,047
I believe it's is greyed out and not active because you're using the device. Mine is set to go to DND at 10pm, but if I am using my phone after 10pm I will get all alerts, IM's, etc.. Soon as I lock my phone, no alerts / noises.
Ledsteplin
Oct 29, 2013
4,814
985
65
Florence, AL
It's active and turned on, but the moon does not get lit up. It's like the screenshot Rafagon showed. If it's not active, it shows nothing. I think if it's turned on before the set time, it shows the greyed out moon. Then at whenever it's set to start it shows the lit up moon. Say you have it set to start at 10:00 pm. If you turn it on at 8:00 pm, it will be greyed out. Then at 10:00 pm it gets bright. But if it's turned on manually before 10:00 pm, it shows bright in the lock screen and calls, alerts will be silenced while locked. I need to start over. :D
Ledsteplin
Oct 29, 2013
4,814
985
65
Florence, AL
View attachment 36329 Greyed out
View attachment 36330 Not greyed out
Just turn it on for scheduled. Turn off manual. It will come on at the scheduled time you have set. If you turn it on before then, you will not get calls and alerts while the phone is locked. That's why it shows bright in the lock screen.
RoofMonkey
Jun 21, 2010
8,867
2,047
Ok, guess you didn't get what I was saying... Even if you turn it on manually and you are using your device it will not be active in DND mode because you are using the device. So it would show as being greyed out. Stop using the device by locking it & it will be active.
If you do not want to be disturbed, why would you being using the device? ;)
App won't let me quote other comments at the moment :(
