Do I have a battery problem? What's normal?
Torinate
Sep 19, 2009
325
Hi there.
Less than a week old 4S. My battery is nowhere near what my old 3GS was like!
I use approximately 1% per minute while reading this forum on 3G.
I haven't noticed a large drop in battery per cent while in stand by - yet. My phone has had a few issues already - not being able to hit the search button on google, lag in forums, kept dropping the 3G service and now a battery that may be suspect.
What i'd like to know is what is everyone elses battery doing? How long does it take to drop a per centage while on the forum for example.
I can tell you, my phone after 8 hours of very low service was at 61%. Maybe 10 texts and 2-3 emails as well as maybe 15 minutes of 3G web browsing. My wifes 4S - more texts but no web was at 88%.
I know there are dozens of battery threads on here. But I was hoping to address this specific concern about my phone.
Rogers service in Ontario.
Thanks!
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Can you post screenshots of your usage and a detailed list of what the usage was (games texting music). This should e monitored over a week to establish a baseline.
Torinate
Sep 19, 2009
325
Here's a couple screen shots.
Doesn't show use though. No idea why. It was fully charged to 100% over night. Not sure why it shows that.
It's dropped 3% in the time to write this post.
Ok forget it. Can't get this thing to upload any pictures.
Guess I'll find a tutorial for this forum.
RoofMonkey
Jun 21, 2010
8,913
1,979
Guess I'll find a tutorial for this forum.[/quote
If your using the app, click on the Open Advanced Options tab, grey bar just about the keyboard. Click photo album and go from there..
Torinate
Sep 19, 2009
325
Holy cow.
I can't find a way to upload pics here.
I can't even email the pics as attachments anymore. They go straight into the email.
Torinate
Sep 19, 2009
325
Not using the app. The pics i've seen from the app are cut off I think. I can't upload from the phone. And I can't email the pics to my laptop as attachments - they become the message. There's no way to save them in the correct format to post.
Is there an easy way to upload from the iPhone without using the app?
Why can't I email pics as attachments like my old 3GS?
Scott Dickson
Jan 8, 2012
Manila
I'm using iPhone 4S 16 GB. I'm fine with my battery life.
Time since last full charge: 18 Hours, 21 Minutes
Standby 1 Day, 14 Hours
Uses (estimate):
emails, Siri, web surf, and social media apps over Wi-Fi (~6 hours a day)
Siri, web surf, social media apps over 3G (~1 hour a day)
games and music (~1.5 hours a day)
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Uses (estimate):
Are you forreal, 18 hours?
fury
Oct 23, 2007
2,274
236
34
Louisville, KY
I don't recall my 3GS ever sending pics as attachments...they always sent as inline images. Then again, I never had a problem saving them from the sent folder or the inbox that I sent them to. What mail client are you using on the computer when you try to retrieve them to be able to post? About the app, the cut off pictures were fixed a while ago. I have no trouble posting screenshots and pics from the phone with the app.
Something definitely wrong right? Im down to 61% battery!
No, that's about what I get. It really depends on how you use the phone. Keeping the screen on a lot (especially with high brightness) is one of the biggest killers of battery life. GPS as well. In fact, a combination of lots of little things can each gnaw away at how long it will last.
In my experience, a few of those "lots of little things" include:
Siri "Raise to Speak" option
Wifi "Ask to join new networks" option
Location Services -> System Services -> Setting Time Zone
Turning those three useless things off seemed to bring my battery life back up to the level I had with the iPhone 4 on iOS 4.
Also, I turn off keyboard clicks and lock sounds to keep the phone from switching the speakers on repeatedly. It may be a placebo effect, but I feel like that also helps. I don't care for the constant sounds anyway. I don't want a Hollywood computer that beeps and bloops at every little thing I do, I just want it to do stuff, and only bleep if I need to check something.
Yankeem0mo33
Jun 28, 2010
44
Ok I started from scratch....down 13% in less than an hour?!?
Location on most apps turned off
Mail fetch turned off (yahoo & gmail accounts)
Brightness switched to auto and set at maybe 1/3
No opened apps
I don't know what else to do. If I take this back to AT&T does anybody know if they'll exchange? My 4 had waaaaay better battery life.
AccordingToAdrian.com
Heacon
Nov 3, 2011
80
Dude your iPhone has been plugged in since last full charge
Sent from my iPhone 4s using iCafe app
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
No opened apps
My battery on new 4S was dropping 1% for every action I made. A text was 1%. Opening app, 1%. I took it to Apple an got a new phone and charger. They said it was an obvious problem and may have been a bad charger also. Since the swap, it's like it should be. I'm @ 62% left now with following usage.
