"dock" background
ddayton217
Aug 7, 2007
Hi to everyone...this is my first post! Ok Im trying to change the what I think is called the dock background. The one with the slide lock on it) I am assuming this can be done with iFuntastic? I ahve searched an dfound the background ones but does the slide lock background have a different name?
marauderrt10
Jul 23, 2007
95
thats not the dock background the slide to unlock it one is called bottomknobgray.png
ddayton217
Aug 7, 2007
Ahh..so find a picture and rename it to that and then its there? What about the slide bar? Does that stay there?
marauderrt10
Jul 23, 2007
95
The slide to unlock button is Bottomknobgray.png, if you want a different color button you change that. You want a different dock background?
marauderrt10
Jul 23, 2007
95
Yes I want to change that background, Like this one!. Thanks!
i don't really know what you mean, every iPhone comes with the transparent dock. If you want to just put a wallpaper you use iTunes to sync pictures with your iPhone and on your phone you select "set as wallpaper"
