Dock icons hard to read
silvermoon
Jul 17, 2013
1,624
179
Washington
As the title suggests, I have the zoom magnification set to the maximum and the icon size pretty small under Dock preferences. You will see in the screenshot I have over 600 email messages. I know... I have a hard time managing my email, anyway, I can hardly read the unread mail count on the icons and have to strain my eyes.
I know there are tweaks in the terminal to increase the size of icons to really big, but I was wondering if there is any app that I might download.
I use my laptop several hours a day and it is painful to say the least to try to see the badges.
28,365
5,506
So you'd like big badges and you can not lie?
28,365
5,506
Seriously, though. I'll look around and see if I can find a tweak that increases the badge size.
28,365
5,506
I didn't see a tweak to increase the badge size. I think the best move is to switch to these options (you can keep your dock on the bottom). When you hover over the icon, the size increases quite a bit and you should be able to see the number much better.
Regular view:
Hovered view:
silvermoon
Jul 17, 2013
1,624
179
Washington
Regular view:
Hovered view:
Thanks! I switched my options close to the screenshot, but once you move past the middle of the slider under size of the icons, there doesn't appear to be a noticeable difference between having it in the middle or to the maximum. I have set the zoom magnification to the highest value. I was hoping that I can increase the size of the regular view. However, it only seems that I can increase the magnification view.
