Dock problem
nanooreg
Sep 26, 2007
24
i don't know if this has anything to do with it by i have an unlocked iPhone and i just updated "customize" through the installer. afterwards, i noticed that i lost my dock icons and they all went to the main summerboard. the dock is there but no icons. when i then went to customize and tried to rearange my sprinboard but i was not able to move anything to the dock locaction. do any of you know how to fix this? Thanks!
Sep 19, 2007
17
Hi, I had the same problem after I upgraded the customize. What I did was I ran xlauncher and I reset the icons. That did the trick for me. After you do this you would have to go back on xlauncher and add the icons you want on the home screen one by one. Hope this helps you out.
David
