Dock won't change
brooke03
Aug 31, 2008
104
33
Memphis, Tennessee
So I have used ssh and replaced the file : /System/Library/CoreServices/SpringBoard.app/SBDockBG2.png
Nothing! And Winterboard doesn't have a dock option. How do I change it?
It's easier to name the Dock you want Dock.png and place it in the theme you're using. WinterBoard will change it.
LionOfTheSouthUK
Jul 23, 2008
82
Thats what I did.
Downloaded Neurox Leopard via Cydia
Then SSHed into the phone to find out where it went ,which was:
private\var\mobile\Library\SummerBoard\Themes\
Then I just created a folder on my PC i.e the folder is titled Blue Theme and in that I placed Wallpaper.png , Dock.png and a folder called Icons (for the couple of icons I wanted replaced) . SSHed that into the Themes folder, rebooted , and changed via Winterboard
Sorry if Im telling you something you already know :)
