Docking problem?
Oct 3, 2007
Hi all,
I've had a problem with my iPhone the past couple of days and wanted to see if anyone has experienced something similar.
When I connect the iPhone to my iMac via the dock, the iPhone syncs just fine, but after a few minutes the phone chirps as if it's just been connected again and repeats the sync. This will continue for as long as the phone is connected to the computer. Sometimes the phone disappears from iTunes, most often, not.
Happens with no one in the room, not something with disturbing the iPhone's seating on the dock. I have replicated the behavior with two different docks, as well as plugging the cable directly into the phone. The USB cable is plugged directly into the iMac and is secure at both ends. iPhone software is 1.1.1, no modifications. iTunes 7.4.2 (4).
Seems to me the dock connector on the phone is shot. I have an appt at the Genius Bar for tomorrow night. Just curious if anyone else has run into this.
Thanks,
Dave
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
While I haven't had this problems myself it's likely that one of the metal receiving prongs on the inside of the iPhone could be bent and would affect the connection you're getting. Have you dropped your iPhone at all or accidentally hit the bottom?
iamtko
Sep 18, 2007
2,004
23
Houston
hmm can't say i have had this exact problem but i did have an issue with my last iPhone.
when i plugged it into the wall at first, it would completely lose signal. later when i plugged it in, the screen would jumble and go completely insane. and later after that when i plugged it in, i heard a crackling/sparking noise so i took it back to Apple(also fiery-like over heating).
and just a re-cap on my return status: the "genius" took a look at it for a few seconds, this included plugging it into a computer and then after seeing what i described, he pulled out a small box, in which held my new friend:)
good luck with your visit to the store tomorrow
eric325
Aug 7, 2007
51
Mine is the opposite. Everytime i undock i lose my internet connection on both 1.02 and 1.1.1 . ( 80% of the time ) I have to restart the computer all over again. Something i just can't figure. Btw have check and read almost all the post for at least a month but could not find another person that have the same problem.
Oct 3, 2007
No, no trauma. I dropped it once back in July but this problem just cropped up in the last week. I have noticed that I can (gently) wiggle the connector back and forth, front to back. Not much play there, but some, and of course I don't know if it was always like that or not.
I think you are correct, I think something's not quite connecting and it's just wear and tear.
Oct 3, 2007
Nice! I'm hoping that's how my experience is tomorrow but I'm afraid my problem is just subtle enough that I will end up with a loaner for a week or two.
Thanks,
Dave
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Oh just thought of something. Do you have a case or just keep the iPhone in your pocket? It might be pocket "sludge" that's wiggled it's way into the acceptor. You might want to try blowing some air into the iPhone to see if any little pieces of lint comes out. Maybe you can buy those compressed air cans for desktop keyboards and try using that. It's definitely worth a shot because mine doesn't wiggle much either so I woulnd't think that the dock was necessarily bad.
iamtko
Sep 18, 2007
2,004
23
Houston
gross man! what in the HELL do you keep in your pockets?!
:p
oh, and with my past Apple experiences, i've been given all new products instead of them actually fixing my old ones.. so good luck with yours!
