does anyone know...1.1.3 question
imaster
Feb 12, 2008
the best thing to do would be to download it and try, if not delete it....
emx620
Jul 13, 2007
110
does anyone know if iLog or callD works for 1.1.3?
I have iLog working on 1.1.3. First install the App. Then SSH into your phone and run the following lines:
chmod -R 775 /Applications/iLog.app
Execture the following commands:
mkdir /var/root/Library/CallHistory
ln -s /private/var/mobile/Library/CallHistory/call_history.db /var/root/Library/CallHistory/call_history.db
Navigate to the iLog dir and execute the following commands.
chmod a+rx iLog
chown root iLog
chmod +s iLog
This lets iLog run as root and fixes the problems of it not being able to alter the call log.
Hope it helps :)
