Does draining the battery help?
sorbet
Dec 11, 2011
78
14
Ohio
My battery lasts a full day no problem, and when I plug it in at night it's usually around 40% or so. Someone at the Apple store told me before that it helps to let the battery drain itself once or twice a month, and then let it recharge fully and carry on as normal.
But whenever I do that, it seems like the battery life isn't as strong as it once was, but I don't really pay too much attention honestly. Is doing this helping/hurting/having no impact on battery life?
Johnlennon78
Dec 25, 2011
43
Hey! It's always good to let any type of battery drain itself once in awhile. Reason is, batteries have memory in them, so if you charge it whenever there is 40% left, it will 'tag' your battery charging @60% all the time so your battery will never be fully charged. Hope that helps
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
Yes it helps. It resets the calibration on the battery so it knows the true zero. Also when it is 100% charged while plugged into a WALL outlet do a hard reset.
  • Like
Reactions: itsalexaye
