Does it matter what brand dock connector to USB cord I get?
theorioles33
Jul 21, 2007
925
135
USA
I would say no. I have some I bought of eBay. 6 footers. They look exactly like the OEM ones but are black. Work fine.
TH55
Oct 30, 2011
356
9
Is there any risk to damaging your phone or compromising charging time?
Jmbaker429
Jun 28, 2010
994
144
35
Same as roofmonkey, I have always had a USB extender on my charger making it 6 feet. Charge my phone with either the iPad or iPhone charger. And have used third party wall chargers and car chargers. Have never had a problem before.
theorioles33
Jul 21, 2007
925
135
USA
oh ok. It might affect the time. I haven't really paid attention but it probably does a little bit.
Yeah I haven't noticed a real difference either. I like the luxury of the long cable as far as being able to sit on the couch or lie in bed without pulling the cord out. :)
Jmbaker429
Jun 28, 2010
994
144
35
I know, its weird that the cord they give you is so short. Pretty much good for nothing. If you need to use your phone while it's plugged in its almost impossible. Definitely nice with the extension.
TH55
Oct 30, 2011
356
9
Which will be faster a 6 foot USB to doc connector or a 3 foot USB extension?
Jmbaker429
Jun 28, 2010
994
144
35
I have 6ft total. I'm assuming the shorter the faster. But in my opinion. The overall difference is going to be very minimal and probably unnoticed. I would say get whichever one length wise helps you out more.
TH55
Oct 30, 2011
356
9
I mean if both are 6 feet of cable, one a 3 ft USB extension combined w the 3 ft factory cable the other all one piece but aftermarket, which is faster?
RoofMonkey
Jun 21, 2010
8,921
1,983
Guess you would need to put a Volt/ohm meter on them to find out for sure. If your using a shielded cable, I think the voltage drop is negligible and won't make a difference.
  • Like
Reactions: Jmbaker429
laughjimbo
Aug 2, 2010
62
Hertfordshire, UK
I use both original lead and I have also got a 2m and 3m leads, I use the 2m lead for tethering my iPhone to MacBook pro as I sometimes want to charge my iPhone whilst using Mac and I need the slightly longer lead as I use it is a lorry and want my phone up on the dash out of the way. I use the longer lead for charging my iPad and iPhone and have compared the charging times to standard length lead and both have been about the same. No problems using them in the past for syncing either.
Laughjimbo
Sent from my iPad2 using iCafe app
