does leaving WiFi on drain the battery?
bkid97
Jun 27, 2007
11
even though im not on the internet but i leave wifi on does it drain the battery or no? aside from that i love the phone...best $600 i ever spent for real
tomjohnsjr
Jul 3, 2007
Yes leaving Wi-fi on will drain your battery as well as leaving Bluetooth on. Just like having your phone in a no signal area will drain your battery real quick.
These services are constantly searching for signal and communicating even when the phone is asleep.
Its best to just turn on wi-fi and bluetooth when you need them.
TrippalHealicks
Mar 2, 2007
1,341
If you have WiFi in your home, and it's staying connected while the phone is idle, i am gonna have to guess tha yes, it is still draining the battery.
kneshoba
Jun 25, 2007
166
Well not with mine, I have had my bluetooth on all day and my wifi, and the battery shows close to 90+% maybe only 10 calls today and a little ipod and a few text messages. Also I was at the Apple store yesterday the genius said you may need to calibrate your battery, i did that the first day i got it. Good Luck!
rumpelgeist
Jun 20, 2007
165
What does it mean to "calibrate" your battery?
Rumpelgeist
SmartAlx
Jun 7, 2007
1,087
I did a google search and found this.
http://www.batteryuniversity.com/parttwo-34.htm said:
When possible, the optimal usage pattern - for any lithium ion battery - is a partial discharge, followed by recharging. A partial discharge can be anything less than a full discharge. However, an occasional full discharge is desirable (e.g., once every 30 charges) to calibrate the battery. (emphasis mine)
http://www.ipodbatteryfaq.com/
Basically, once a month fully drain your battery to recalibrate.
wjp09
Feb 25, 2007
2,559
25
NJ
I think as long as you are connected no. But if it is searching then yes
BWGrapher
Jun 19, 2007
55
I found..
I found this on Apple webpage.
http://www.apple.com/batteries/maximizing-performance/
Also, I found this, too.
iBooks and PowerBook G4s other than the PowerBook G4 (15-inch Double-Layer SD)
  1. Plug the power adapter in and fully charge your computer's battery until the battery indicator lights turn off and the adapter plug light goes from amber to green, which indicates that the battery is fully charged.
  2. Disconnect the power adapter and use your iBook or PowerBook. When your battery gets low, you will see the low battery warning dialog on the screen. Continue to use your computer until it goes to sleep. At that point the battery has been sufficiently drained for calibration.
  3. Connect the power adapter and leave it connected until the battery is fully charged again.
You have to fully charge and then discharge your battery only once to calibrate it. After that, you can connect and disconnect the power adapter when the battery is at any charge level.
Tip: When the battery reaches "empty", the computer is forced into sleep mode. The battery actually keeps back a reserve beyond "empty", to maintain the computer in sleep for a period of time. Once the battery is truly exhausted, the computer is forced to shut down. At this point, any open files could be lost. Therefore, it is important that you find an electrical outlet and connect the adapter before the forced shutdown occurs.
PowerBook G4 (15-inch Double-Layer SD), MacBook (all models), MacBook Pro (all models), and MacBook Pro (17-inch) (all models)
The battery calibration for the PowerBook G4 (15-inch Double-Layer SD) and any model of MacBook or MacBook Pro has been updated because of a new battery released with this computer. With these computers, follow these steps to calibrate your battery:
  1. Plug in the power adapter and fully charge your PowerBook's battery until the light ring or LED on the power adapter plug changes to green and the onscreen meter in the menu bar indicates that the battery is fully charged.
  2. Allow the battery to rest in the fully charged state for at least two hours. You may use your computer during this time as long as the adapter is plugged in.
  3. Disconnect the power adapter with the computer still on and start running the computer off battery power. You may use your computer during this time. When your battery gets low, you will see the low battery warning dialog on the screen.
  4. Continue to keep your computer on until it goes to sleep. Save all your work and close all applications when the battery gets very low, before the computer goes to sleep.
  5. Turn off the computer or allow it to sleep for five hours or more.
  6. Connect the power adapter and leave it connected until the battery is fully charged again.
Tip: When the battery reaches "empty", the computer is forced into sleep mode. The battery actually keeps back a reserve beyond "empty", to maintain the computer in sleep for a period of time. Once the battery is truly exhausted, the computer is forced to shut down. At this point, with the safe sleep function introduced in the PowerBook G4 (15-inch Double-Layer SD) computers, the computer's memory contents have been saved to the hard drive. When power is restored, the computer returns itself to its pre-sleep state using the safe sleep image on the hard drive.
After read this, I think you can get the idea.
