Does the speaker in your phone buzz?
Aug 5, 2007
The sound of my phone is often distorted or sounds like the speaker is loose. I notice it when listening to the # I'm calling ring or on about 50% of calls. Reducing the volume does not help until it is too low to hear. Any one disappoined with the sound of the phone?
BB
iGal
Jul 27, 2007
170
SoCal
I haven't experienced that myself... is there an Apple store near you, where you could have them take a look at it?
abohsali
Jul 12, 2007
45
If you are talking about the speaker on top of the screen then I know what you are talking about. I had this problem with two phones straight out of the box. I took them back to the Apple store and they gave me new ones right away. It is probably the thin membrane on top of the speaker (inside - you can't see it) that is loose or has a whole and gives a buzz at high output/volume. Take it back and they should replace.
-Bohs
Aug 5, 2007
-Bohs
thanks, I was wondering if it was a defect or a common thing..I'll try the store
Bb
