Does your iPad 2 case fit the new iPad?
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
Taking a bit of a survey. If and when you receive your new iPad, please test it with your iPad 2 case. Let me know what case you have and if it fits.
BoLoThaBeAR
Mar 9, 2012
69
Yes the Griffith did fit my new ipad...
Howevr im waitn for the new Marware ceo for the new ipad to arrive :)
RoofMonkey
Jun 21, 2010
8,921
1,983
I purchased the Otterbox Reflex case from the EverythingiCafe store.
It was advertised as a case for the iPad 2. It will fit the 3, HOWEVER, it is such a tight fit I think it would peel a screen protector off the screen!
Took me at least 5 minutes to get each half off and there is a bit of marking left on the back. Nothing terrible though.
We will call it some light marring, not scratches.
Josh Yates
Jul 14, 2007
563
32
Orion, MI
I had the Belkin Snap Shield...no dice. The iPad Smart Cover works fine, but no to the Snap Shield. It's going back to Best Buy. Scratches horribly, as well...doesn't hold up well at all...
Smarty2600
Apr 23, 2011
344
11
I had poor luck with the Belkin snap shield with my old iPad 2 anyways. I bought the shield and put it on but then took it off because some crud had gotten underneath the shield and it just snapped. Luckily I was able to return it to best buy for a full refund, but I then decided that a colorful skin would work better.
As for the iPad smart cover from my iPad 2 it fits perfectly on my new iPad.
billnye97
Jun 21, 2007
851
77
Cleveland
I used the Apple smart cover and I got from Amazon the Smart cover snap on case. It only cost $4 and it fits perfectly.
mbairguy
Mar 8, 2012
175
62
Birmingham, AL
When I heard that the new iPad could be larger...I' ll have to admit, I was a bit worried that it might no fit the "ole case" (which is what I call it). Happy to report no issues whatsoever.
iphoneint
Feb 9, 2012
64
When I heard that the new iPad could be larger...I' ll have to admit, I was a bit worried that it might no fit the "ole case" (which is what I call it). Happy to report no issues whatsoever.View attachment 22578
Hate to tell you that I think the new iPad sticks out a bit in that old case of yours. I would be worried that it would fall out and break.
mbairguy
Mar 8, 2012
175
62
Birmingham, AL
Double-sided heat tape bonds it to the lid. Functional and beneficial. The wife doesn't care much for it in bed, but its perfect when sitting in a chair. The airlines hate me...
verwon
Jul 29, 2011
1,015
121
Seattle
I never bought a regular case. I use the SmartCover and a Targus neoprene netbook sleeve, s they've easily transitioned to my new toy.
Sent from my iOS ecosystem!
The Kace
Aug 15, 2010
BoLo ... Thinking about doing the same. Where did you buy your Mareware? Did they make a new case for the New iPad or is it the one I see on the net for iPad 2? Cost?
Thanks!
BoLoThaBeAR
Mar 9, 2012
69
U should its a great case....
Directly from marware.com. Its for the 'new ipad' & i paid $44 shipped.
