Does your Phone do this?
PARADA6
Jun 28, 2007
46
Today I accidentally grabbed the left side of the black backing and I actually pushed it in a little bit. To make it clear, it's the area I circled in red in the picture. When I push it it goes in a little bit and comes out itself. The casing is perfect by just looking at it and I never drop the phone.
Is this happen to your phone as well or it's just mine?
scrowner
Jul 4, 2007
120
Yep. I have the same squishy plastic at the same point. It is a little disconcerting when it happens that I push that spot - but I have noticed no shape change of the plastic. So - I have not been worried about it.
alb0zf1n3st
Jul 2, 2007
624
Its something that is there they bothers you but just pretend it doesn't bother you and pay no attention lol..
PARADA6
Jun 28, 2007
46
Probably it will bother me for 2 more days:) but seriously as long as there's no dent I'm fine with it.
dietPEPSI
Jun 29, 2007
80
mine doesn't do that
In fact I kept pushing on it trying to get it to feel squishy but it wouldn't
minivini
Jul 6, 2007
418
Doctor, when I try to put my leg over my head, it hurts.
Doctor says, "Don't put your leg over your head."
:laugh2:
Sorry, couldn't resist.
Standog
Jun 26, 2007
97
It's already been mentioned that as part of the design that this part of the phone is plastic to allow for better reception for the phone's antenna, which is under this part. The antenna would have problems going through the other metal parts of the phone. Hope this helps. It's not a design flaw.
iCop
Jul 7, 2007
87
Tucson, AZ.
I am on my 4th iPhone now. Here is why:
1st phone: 4 gig - took it back to upgrade to 8 gig
2nd phone: 8 gig - exchanged it because mine had a very loose casing (spot you all are talking about, but visibly loose.
3rd phone: 8 gig - the day they exchanged it for this one I noticed a software glitch where I had little white squares blinking on the top and bottom of te screen when I scrolled. This phone too made the squeek noise in the same spot.
4th phone: 8 gig - got it today and so far it is flawless. No software glitch, no squeek noise or feel, and for some reason this one just feels better. It is much more responsive when typing too.
