Don't Set Springboard to 0 Icons
Boatski
Sep 7, 2007
81
So I set my springboard to 0 icons so the rest would be on the extended springboard. Well now I can't scroll over to see the rest of my icons. The only icons I have on my dock is my phone, safari, and text.
I can't restore because I'm at work >.<
Boatski
Sep 7, 2007
81
All I have access to is Phone, Text, Safari, & iPod with the double click home button.
iMerlin
Sep 20, 2007
662
Algonquin, IL
Yeah boatski, the springboard will not work like that. The main purpose of having the ability to set it to 0 is to not have any at all, the extended springboard only works when the main springboard is full. Setting it to 0 is cool when you have the Dock application installed like Greg mentioned. That allows you to access all your apps from a little sunburst in the bottom right hand corner of the springboard. Dock is a must have IMO.
Anyway, you may not have to restore if you have iBrickr at home. You can connect to iBrickr, then load Dock from iBrickr and then access Customize from the dock application. It still sucks that you have to wait till you get home, but at least you wouldn't have to go through a restore.
Hope that makes sense.
Boatski
Sep 7, 2007
81
Sweet, thanks. I'll run home before class tonight and give it a go. iBrickr works with 1.1.1 correct?
iMerlin
Sep 20, 2007
662
Algonquin, IL
Only version 0.91. Good luck.
By the way, the Dock application is also what everyone uses to take screenshoots of your iPhone. Pretty cool...
You can see the Dock in the bottom right hand corner. Its tiny but its there.
TW1ZTD
Sep 11, 2007
19
It might just be me but Ibrickr .91 doesn't work with my 1.1.1 iPhone. When you try to run it, it asked you to down grade to 1.0.2.
iMerlin
Sep 20, 2007
662
Algonquin, IL
Ive seen some people have this issue, Im not sure why. It works good for me. One warning though, it still doesn't do ringtones.
Boatski
Sep 7, 2007
81
Installed Dock but it takes me straight to my contacts, that's it.
iMerlin
Sep 20, 2007
662
Algonquin, IL
It is hard to get used to the dock, don't tap the corner...drag your finger from the corner to the middle of the screen and keep your finger on the screen, all of you apps should pop up.
Boatski
Sep 7, 2007
81
That makes a lot of sense haha thanks
