Dose Anybody Know If Jailbreaking Is The Same For All The Firmware
tpain
Oct 9, 2007
39
Dose anybody know if jailbreaking is the same for all firmwares like 1.0.2 1.1.1 and 1.1.2. thanks
tpain
Oct 9, 2007
39
Do you know where i can find how to jailbreak the 1.0.2 and activate it cant find it anywhere. thanks
kariya9mdoa
Oct 26, 2007
80
Jailbreak 102
First you need to tell us what are you using pc or mac both use a program called apptap and if your a mac user the best is independence it is easy to use but make sure you have the right framework for iTunes or it keeps stopping and you have to keep restoring (i did this a lot and then i found out what to do) if you are using a pc the the best i believe is ibrickr. if you have any trouble just drop us a line and i will help all i can.
HappyModding
