dots on Calendar...on every day!
todesto
Sep 30, 2007
59
Hi, all
All of sudden, I notice theare dot indicating there's a event on everyday of the month calendar as shown in above pix and I cannot figure out how to remove them. :oops:
Can anyone help me? Thanks in advance.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You must have an event set to recur everyday. Open you event and click the edit button and change remove the repeat setting.
Lips2000
Jun 4, 2007
100
Houston, TX
Also, you might to check to see if you scheduled an event that lasts for a year. Easy to do.
Mark
todesto
Sep 30, 2007
59
How do you check that? in iPhone? or outlook? Is there a simple way to check which one is check to occur everyday?
I don't see anything that is checked to repeat everyday. Besides, if it is to repeat everyday, shouldn't it show in detail box?
Thanks for your help.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
In the iPhone click calendar, and click a date with the the dot, then click that item and hit edit, then click repeat and then click never. That shuts it off.
Spikefood
Oct 3, 2007
368
Not sure if that would work. If you look at the picture there is no event listed on the day that he has selected, even though it has a dot.
wildor
Nov 19, 2007
19
dots
I had the same thing happen last week but
its was for about 10 days of dots with no events.
I turns out that I had a previous event set to last all day
but the end time of the event was accidentally set to
the day BEFORE the event. For some reason it added
the 10 dots/day with no events?
RLK
81
Indialantic, FL
You need to search back until you find the first date (could be months or years) that has the dot. When you find it, the start time will be greater than the end time.
djax
Mar 22, 2009
In the past AND identical start and end times/dates
The fixes above did not solve my problem because there is another twist. In addition to what others have mentioned about ending in the past, the dots fill every day if you schedule an event that begins and ends at the same time. For example, I had recurring birthdays set for 12am to 12am on the birthday (0 minutes). The extra dots disappeared once I changed to a 5 minute interval for these events (eg. 12am-12:05am). I changed Outlook, which is synced with the iPhone and cleared it up.
