Downgrade
Navaskdl
Dec 27, 2010
100
Hi
I have shsh blobs of 4.3.3 saved with ifaith and custom ipsw built with it. Recently I updated and jb to 5.0.1. Now how do I downgrade to 4.3.3 using this ipsw?
Moved to iPhone Jailbreak.
Install TinyUmbrella and check 'set hosts file to cydia on exit' then shift + restore in iTunes. Anticipate an error at the end of the restore. You just need to use Fix Recovery to kick it out of recovery mode after the error.
Navaskdl
Dec 27, 2010
100
Thanks for the reply Europa, on the tiny umbrella part I should start TSS server, then keeping it open have to open iTunes and shift restore by pointing to the custom made 4.3.3 with ifaith. Am I wrong? One more thing I forgot to mention is that right now in my cydia it shows blobs of only 4.3.5 and 5.0.1. Does it matter?
If 4.3.3 isn't saved in Cydia, you'll have to use the TSS server and the SHSH blobs that are stored on your computer.
