Downloading "Customize"
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
Worked great! Now, how do I remove unwanted icons from my phone?
Chris
You wish to "hide" them or remove the software entirely? To hide them using customize you would go into rSBT, in the icon list select the icon for the program you wish to hide, a little 3 bar icon will appear on the right side of the selected program. Putting your finger on that drag it down below the "Hidden" bar at the bottom. The software will still be on your phone but the icon will not be displayed until you drag it above the hidden bar again.
To remove the software (as long as it is not one of the native programs built into the phone) you would have to use installer and remove it.
