Downloading updates
Aug 18, 2012
I'm having trouble downloading updates for 7 of my apps. I seem to be stuck in a loop. Does anyone know how to stop updates from downloading?
iphonewarrior
13,847
699
You must have selected update from your device as the apps wouldn't update automatically.
If you're having a problem with getting them to fully update on your device you will need to connect your phone to your device and sync the apps to your phone. You should also be able to Tranfer Purchases which should transfer all updates from your computer to your phone and vice versa.
li2327
Jun 17, 2009
104
www.myspace.com
I was having downloading issues as well. I had to connect to wifi Nd it allowed me to download. That may help. Good luck.
