Drag and Drop from iPhone to PC?
FeistyGirl
Jun 25, 2007
40
Glen Burnie, MD
Hey everyone.
I use iPhonebrowser to drag and drop files onto my iPhone (it's a godsend when adding new themes and such) but it doesn't do the opposite. I can copy single files but that can get tedious.
Is there a windows utility similar to iPhonebrowser that allows you to drag and drop directories and multiple files from the iPhone to your PC?
Thanks!
Chrissy
W00Ki3
Oct 12, 2007
TX
Enable SSH on your iPhone, then FTP into your iPhone.
I used Installer.app to get the necessary files.
1. Get Installer.app (Make sure Community Sources are installed)
2. Install "BSD Subsystem"
3. Install "OpenSSH"
4. Use an FTPS compatible client like FileZilla to connect to your phone.
iPhone and PC must be on the same network for this process to work properly.
To Connect, you need to find the IP Address of your iPhone. Use this IP as the Server, User Name: root, Password: dottie
After that, search through the folder system to the desired directory
bigmac
Jul 13, 2007
110
Los Angeles
where do you put the IP address of your phone?
truehybridx
Oct 31, 2007
40
oh wow lol
yes thats probably why
its better if you have your computer and iPhone on a closed network... even sever your internet connection when you do it because sometimes with me SCP skips right onto the internet looking for my iPhones ip
bigmac
Jul 13, 2007
110
Los Angeles
oh wow lol
any ideas if you don't have a wireless access point?
truehybridx
Oct 31, 2007
40
umm I can't name of anyways to do it that gives u as much access likeSCP does but I'd really like know of a better way to
